whats faster than a raptor?
depends on how far the race is and on what terrain////
raptor with a $10 front sprocket change can go really, really fast (85mph stock)
but those 450's accelerate faster over short distances
think according to these forums....everything is faster than a raptor by the way peeps post
I ride with rappies all the time, and a couple yfz. Topped out, nothing stock will touch the rappy. The yfz is fast, faster than a z, but not as fast as the rappy. And with gear swaps,and higher rev limiter a rappy could easily break 100mph. The z is more at home on a track than a stock rappy, though. Unless you change a-arms, axle and suspension on the rappy.
sure you smoke crack,,,a raptor could easily run 100 mph,,,
the only quad EVER i saw to run very high speed run (in the upper 90 mph) only with a gearing change is the DS 650,fastest high speed run you can go only with a sprocket changes,cauze the ds feel at home at high spedd cauze of the wider,smoother frame cuts.
stop the bull,yamaha is fast,but there is some thing out there
you should learn about from...
