what psi to run new razrs
Old Jul 10, 2004 | 12:50 AM
traildogg's Avatar
Default what psi to run new razrs
hi i just got my maxxis razr 1 tires 22x11x9 rears they left them at 20lbs what do you guys run them at these are on my 97 warrior i only trail ride and weigh over 300 lbs what psi should i run them at any help appreciated thanx.
Old Jul 10, 2004 | 01:51 AM
DS650BajaRunner's Avatar
That is way too much you might want to put then in 4 or 3 lbs since they new. When you start to notice wear on the tire go down one lbs i run mine at 1 lbs but thats because i am light i am 120 lbs so i need them to have a little more grip. But you should be fine with 4 or 3 lbs
Old Jul 10, 2004 | 03:27 AM
Hayseed's Avatar
My 22x11x9 Razr's tend to hump up in the middle with too much air. I have ran them at 2lbs. to get them to wear flatter but usually around 3 to 3 1/2.
Old Jul 10, 2004 | 03:37 AM
Warrior350ripper's Avatar
i got 5psi in my 22/11/9 holeshot ....u can use less if u don;t ride agressive
Old Jul 10, 2004 | 03:52 AM
Hayseed's Avatar
warrior350ripper, was that supposed to be a slam? My tires are 4ply and don't flex much. I ride plenty aggressive, so you might not want to assume that you need 5psi to keep a tire on a rim.
Old Jul 10, 2004 | 07:58 AM
craZ400's Avatar
My neighbor has 4-ply razr's on his rappy and runs 2-3psi. He weighs about 230-240. Did you get the 4-ply, or 6-ply?
Old Jul 10, 2004 | 01:02 PM
dude i'm not assuming or slamming anyone..i'm, just telling u what i got in my tires ..i used to have 2/3 psi but i like to throw my quad around and i lost some air....always felt like the tire were flat...and there 6 ply
Old Jul 10, 2004 | 02:41 PM
I assume you mean hard pack because if you throw those thing in mud with 5 lbs you aint going nowhere. The psi you run also depends on where you are riding start at a high number like 4 or 3 if you see the tires are not doing well go down because once you go down lbs you cant go up unless you have a way to add some air.
Old Jul 10, 2004 | 03:03 PM
actually ...i think its better cuz my skid plate rides over the mud ..instead of threw it .......i just gave my opinion but u all do what ya like[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 10, 2004 | 03:08 PM
warrior68man's Avatar
I have 6ply razrs in the rear and I run them at like 5.5lbs and they are fine.
The fronts I never really check just make sure theres air in them becuz they arent the ones delivering the the power.
