RAPTOR PERFORMANCE
Old Jul 10, 2004 | 05:16 PM
OSMAN's Avatar
Default RAPTOR PERFORMANCE
WHAT ARE SOME GOODS RAPTOR MODS THAT MAKE THE MOST POWER ADD ON'S ONLY. I ALREADY HAVE A FULL YOSHI SYSTEM, JET KIT, 4.5 EXTENDED SWINGARM, K&N. WHAT ARE SOME MODS I CAN MAKE
Old Jul 10, 2004 | 05:55 PM
Voodoothenoob's Avatar
686.......................
Old Jul 10, 2004 | 08:15 PM
XxDumontRaptorxX's Avatar
Wow, must be real fun riding a piped quad with an extra 4.5 on the swing arm [img]i/expressions/face-icon-small-wink.gif[/img]
Anyways Vodoo said go with a 686, I would suggest maybe a drop in cam(stage 1, unless you want to change valve springs), 11:1 piston, maybe a port and polish. To get 686 cc's you have to bore it to 102mm's i believe, which leaves you with no more bores on that sleeve. I would suggest a 101mm piston just because a few extra cc's will only make a small diference. It would save you money if you ever need another bore.
Old Jul 10, 2004 | 11:08 PM
OSMAN's Avatar
WHO DOES A GOOD JOB ON PORT AND POLISHING THE HEAD AT A GOOD PRICE
Old Jul 10, 2004 | 11:49 PM
garyc660R's Avatar
If you have no aftermarket cam, port and polish is a waste of money. The very popular Hot Cams (no core charge) stage 1 requires no spring change, and porting is not recommended, from the builders I have talked too. Stage 2 requires stiffer springs and porting helps out. Contrary too what you may read here recently, porting is the last element too be added too a modded 4 stroke engine. Huge amounts of power are available through porting on a 2-stroke, but a 4-stroke does not see the massive gains in porting. It's the icing on the cake for a thumper. $350-400+ dollars does not justify 3-4 horses.
Gary
Old Jul 10, 2004 | 11:54 PM
ZimRaptor's Avatar
i feel its pointless...if it could of been done any better yamaha would have made it better, but since some people claim they didnt then it must not be reliable...it just doesnt add up
Old Jul 11, 2004 | 12:33 AM
sixsixT's Avatar
Like Gary said if you use a stage 1 cam porting isn't going to make a huge difference but if you put in a cam that wants lots of RPMs it's a must.IMHO
Old Jul 11, 2004 | 06:43 AM
14mins's Avatar
do away with the airbox, or at least open it up. sixsixt made a cool air intake system that is worth every penny. If you ride alot and plan to put a piston in, i would suggest that you stay away from JE. JE has made a few running changes and they still fall apart at a higher rate than they should IMO. Some builders swear by them, but i have seen a pile of busted ones first hand. For a piston i would suggest a Ross or CP. Stage one drop in cam is great. I would skip the advanced degree timing key. Non O Ring chain is good for a little extra free power. Aftermarket CDI box will do nothing for you at this point. You might try some oxegenated fuel in the 92 octane level[img]i/expressions/face-icon-small-wink.gif[/img] You can tweak on the schocks and tires to get max hook up. You might try a 1/2 inch spacer plate in front of the carbs. If you do that you might as well clean up the inside of the carb boots to make it match a little better. You could also try a set of turbonators in the carbs ( 40 bucks) and a nology wire. ( i could not give you a desicion on the last 2 of making more power though) In theroy they should but in reality??????
Old Jul 11, 2004 | 09:30 AM
BURKEDADDY's Avatar
hello where can i find sixsixt's cool air intake system and some more info on it
thank you
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
