Im leaving for a month!!!!
Hey guys im leaving the states for a month.. i was wondering what i should do to my rappy when i leave. it will be in my garage so i was wondering if i should turn the gas off and let it run so all gas gets out of the carb? if i do this and let it sit is it good for the quad?
any other suggestions?
where you going? Im going to Monterrey, N.L Mexico next monday and will be unreachable for like 3 weeks! Cant wait to go! Have fun and be safe.
BTW, I'll be driving down there, love long road trips to Mexico (third time going to MTY).
This is what i do when i am going to be gone for more than two weeks at a time.
I air the tires up to about 8 to 10lbs so that the tires wont go flat if they have a slow leak and sit on the sidewall with the wheel.
I shut off the fuel and run the engine for a few seconds before cutting it off,
I then take a screwdriver and open the float bowl drains and let all the fuel run out of the carbs,
Then i try to start the bike one more time to get that last bit of fuel out of them.
Lube the chain good so it wont rust and spray a little WD-40 on any exposed steel, (such as where my boots rub the frame)
Before i broke it, i used to plug my bikes into a trickle charger that keep a full charge on the battery at all times.
Other than that not much to do, I just dont like cleaning the carbs on my rappy so i drain them when ever they are going to sit for any period of time.
Hope this helps
Tyson
Hope this helps
Tyson
Good lord. I would save that much work for anything over about 2 months, but 2 weeks? Not to say its not a bad idea, its just a little more work than I would do for that short of a time.
I usually just turn off the gas and run it dry, good e'nuff.
Hope this helps
Tyson
Hope this helps
Tyson
that is all i do and i let it sit in my garage longet than 2 weeks man thats nuts you must keep that quad in nice shape
That all seems like a lot of work, but it only takes about a minute. I got in the habit when i had alcohol carbs on my crotch rocket, the alcohol would evaporate and leave a chalky residue inside the carbs.
Besides if i dont drain the carbs when i stand it up to wash it, the gas runs back through the filter and i end up with gas and K&N Filter oil in the little plastic drain hole thingy.
