what kind of oil do i put in my banshee tranny???
Old Jul 16, 2004 | 02:49 PM
AlkyBurninX's Avatar
Default what kind of oil do i put in my banshee tranny???
Dan250, the Belray Gearsaver I was talking about which is made specifically for 2 stroke trannys is 85W.
Old Jul 16, 2004 | 02:51 PM
iwantaTurbo's Avatar
how much does it hold?
Old Jul 16, 2004 | 02:56 PM
kingofthemudholes's Avatar
u use belray in all my quads
Old Jul 16, 2004 | 03:40 PM
1500 cc/ml. If you buy motul or belray it is in 1000 cc/ml bottles (just bigger than a quart). It takes one and a half of them per oil change.
Old Jul 16, 2004 | 03:49 PM
  #15
HiFlyinRaptorRyder's Avatar
I also use the Honda Pro. I started putting 2 quarts in after I welded the clutch rod and ball. I have yet to find any downside to using 2 quarts and it makes it virtually impossible to weld the rod and ball.
Old Jul 16, 2004 | 04:11 PM
  #16
whats the ball and rod do? whay would yo weld it?
Old Jul 16, 2004 | 08:25 PM
  #17
2004LEBANSHEE's Avatar
YUP, ran both 80 and 85. I dont know what hes talking about
Old Jul 17, 2004 | 01:19 PM
  #18
Welding your ball and rod is a term that means the ball that is between the rod and the clutch adjuster gets so hot they melt together.
Old Jul 18, 2004 | 12:34 PM
  #19
And this happens when you hold the clutch in for long periods of time while revving the engine.
Old Jul 18, 2004 | 12:55 PM
  #20
86250rrider's Avatar
my opinion is to stay with dino oils ,change more often.synthetics have fu@ked me before with slipping on an otherwise good clutch setup(resulting in a rollover,about 6 or 7 times to be exact!) i use the honda pro in the red bottle. my 2 cents.........im out[img]i/expressions/face-icon-small-happy.gif[/img]
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
Logan Collins
Sep 5, 2015 08:03 PM
