what kind of oil do i put in my banshee tranny???
80WT........that is too much there banshee boy. You are roosting clutches, that oil is to thick to properly lubricate your WET clutch. I don't know if it has any adverse effects on the bearings, but I would switch to a lower wt oil. Oil is not PERFECT out of the bottle, it must go through a chemical breakdown involving heat before it becomes most effective lubricant. 80 wt has to get DAM HOT to start lubing good for a quad tranny, and as we all know the stroker tranny does not get very hot - not hot enough for 80 wt. I would use a 30 wt , but not any more than 50 wt.
