losing power on Griz
Old Jul 14, 2004 | 11:15 AM
Starky's Avatar
Default losing power on Griz
Lately it seems that I have been losing power on my Griz. Last night I was riding on the MX track and really noticed it had less power going up the hill. Except for the air filter, it is bone stock. It isn't sputtering or back firing, it just feels like the power is missing. Could it be that my valves need to be adjusted. I have about 700 miles on it and still haven't had the valves checked for adjustment. What normally happens when your valves are out of tolerance?
Old Jul 14, 2004 | 01:57 PM
pinheadedjoker's Avatar
Yeah i would get ur valves adjusted it wont bring in as much air or let out as much if its not running properly go get a tune up.. get the valves adjusted change the oil grease things taht need to be greased.
Old Jul 15, 2004 | 08:59 PM
Vakero's Avatar
This could be a valve problem. If your exhaust valves tightens up too much it can burn your valve seats, then it is off for a valve job on your new machine. If your exhaust has too wide a gap it will act as a restricter. If your intake valve tightens, again valve job and in extream cases intake problems. If intake has too wide of gap the carb won't deliver enough fuel to the piston.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
