raptor shock squeak?
Old Jul 19, 2004 | 07:02 PM
duke9074's Avatar
Default raptor shock squeak?
my front right shock squeaks when riding and if i push down on it slowly it make like a grrrr but i try everthing to spot it and ideas i sprayed wd40 in it white grease in the top and bottom pivot pionts any ideas. Could it be metal grinding thats bent i didnt hit anything?
Old Jul 19, 2004 | 07:03 PM
pinheadedjoker's Avatar
mine squeeks to dont know why
Old Jul 19, 2004 | 08:01 PM
RacerRob's Avatar
Mine usually squeak after riding...its usually just dust on the shocks. So I just give it a high-pressure wash, and it goes away until the next ride.....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 19, 2004 | 08:07 PM
Gwinnwarrior's Avatar
the same exact thing has been haunting me all summer too and i just recently found out the culprit. thats wierd you asked just as i figured mine out..lol anyways....
i took my rear shock off and put a little bit of grease on the shock bolts, top and bottom and then put them back in and it hasnt done it since. i dont see why it wouldnt work for the front shocks, its the same thing. dont put alot on the bolt itself, just put a little bit, a light coat should do the trick. i dont know how long it is good for becuase like i said i just did it last month and it still hasnt squeeked once for me.. give it a whirl, it wont huirt anything. good luck!!!!!!
Old Jul 19, 2004 | 10:45 PM
HughJazz's Avatar
Try taking the mounting bolts out and lubbing them with grease. I did this on my rear one
Ahtatu
Sep 28, 2015 12:14 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
Canamaniac!
Sep 4, 2015 06:44 PM
