Adjusting Parking Brake
Old Jul 20, 2004 | 02:37 PM
04Raptor350Guy's Avatar
Default Adjusting Parking Brake
Hey I was just wondering if anyone knows how do adjust the parking brake on the Raptor 350 or the Warrior I guess would work too. I don't have an owners manual. I heard on another post that you have to tighten up a bolt or somthing. The parking brake is really bad. I had it on and I was pushing it around and I didn't even know it was on!
Thanks
Old Jul 20, 2004 | 02:40 PM
RoostItUp's Avatar
The best thing to do is just take it off and buy a block off plate! Those things are sooo worthless, you have to adjust them all the time and I don't ever have times that I absolutly NEED it.
Old Jul 20, 2004 | 02:42 PM
Well I don't really want to take it off lol
Old Jul 20, 2004 | 02:46 PM
pinheadedjoker's Avatar
ive never seen a parking brake work correctly..
Old Jul 20, 2004 | 05:03 PM
HoundDog06's Avatar
To adjust it, you need only screw in the bolt which sticks out horizontally from the rear caliper.... However, these guys are right. The parking brake on the banshee/warrior/raptor660/raptor350 do not work. They will constantly need readjusting and will finally fail completely beyond adjustment. The best thing you can do is take it off. It's a standard quad, just leave it in gear in lue of a brake. But the decision is yours.
~HoundDog
Old Jul 20, 2004 | 06:28 PM
Rock777's Avatar
You do have to adjust these pretty often, but if you want to keep it on there it only takes two seconds to adjust. As Hounddog said you do have to tighten the bolt that sticks out from the rear caliper, but to do so you have to losen the nut first so the bolt will screw in. Once the nut is lose, turn the bolt in with your hand until it stops, then tighten the nut again and it should be okay.
Old Jul 20, 2004 | 08:18 PM
NotuRaptor2's Avatar
Generally, you will end up wearing your brakes out quicker. When you use the manual cable to pull the brake caliper, it doesn't quite release all the pressure especially when the cable gets full of crud. You don't realize it because it isn't much of a drag but it is certainly enough to put pressure on the pads against the brake rotor. Thus, your brakes wear out quicker. Even if you don't won't to remove the e-brake, never use it!!!
Old Jul 20, 2004 | 08:30 PM
clover's Avatar
the parking brake does suck on them things, mines doing the same thing to i, can flip the parking brake on and i can push it around.
Old Jul 20, 2004 | 08:40 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
mine worked when it was sitting i nteh dealership and about an hour into first ride.. but aint worked since.. can't wait to take that pos off started makin my braek rub
Old Jul 20, 2004 | 10:07 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Everyone has given you good advice. The design of the yamaha e-brake is old and flawed. It is a common practice to purchase a yamaha,,,and immediately remove the e-brake system.
If you do keep it in adjustment (every ride) the rear brakes will likely drag and wear the pads out quickly. Usually removing the e-brake improves brake pad performance.
The seat makes a pretty good wheel chauk if it starts to roll[img]i/expressions/face-icon-small-wink.gif[/img]
dont forget to leave it in neutral when trailering
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
