What keeps blowing the seal?
Old Jul 21, 2004 | 10:33 AM
Shav0's Avatar
Default What keeps blowing the seal?
Twice now in the last month somthing in my engine has been going wrong. It keeps blowing the crankseal and drawing in tranny oil into the cylinder...The first time I didn't think much of it, but the second time has me wondering. What could be causing it to blow out like this? Could pressure from the case be getting out and pusing out the seal? Could it be the crankbearings?
Thanks
Chad
Old Jul 21, 2004 | 12:18 PM
bvwarrior's Avatar
try to change the oil and oil filter. that might be the problem. because if to much stuff is in the oil filter it will block and create pressure and that could blow seals
Old Jul 21, 2004 | 12:47 PM
Shav0's Avatar
no oil filter...2-stroke,
Old Jul 21, 2004 | 12:50 PM
AlkyBurninX's Avatar
I think he is talking about his blaster, which don't use an oil filter.
If you crank bearings were shot, you would know it. A little play in the crank bearings is TOO much. You might try polishing the crank journal where the seal rides. It might be a little rough or uneven. Make sure your trans case vents aren't stopped up. If so it could build pressure which would be hard on the seal.
Old Jul 21, 2004 | 12:53 PM
TheRaptorMan's Avatar
I had that problem with my old RM125 and it ended up that the crank was bent. It was going through the seals like candy, and when I split the case sure enough crank was bent... Hope its something simpler and cheaper for you!
Old Jul 21, 2004 | 01:16 PM
Shav0's Avatar
The first time I had this problem, about 3 weeks ago, It would run fine in nutural but the minute you put it in gear you could hold it wide open and it would just bog and smoke really bad..At first i thought it was just the plug fouled. I took it to the dealer and sure enough the crank seal was tore right out of its place and was shreaded up into little pieces. I got it fixed and it ran perfect, up until last night. it is acting jsut like it did before when the seal went the first time but what I can't figure out is why...When we replaced the seal the first time, the crank and bearings all looked to be perfect..So that can't be it..
Alky, You mentioned that the breather could be blocked? Come to think about it Back before the seal went the first time I had re-routed the breather tube from under the hood to go under the seat to the airbox..Do you think maybe the weight or somthing of me on the seat is putting a kink in the tube and not allowing the air to pass? Could It build up enough preassure to blow the seal..twice?
Old Jul 21, 2004 | 01:29 PM
It could be kinked. It can build up quite a bit of pressure. I have seen the trans output shaft (behind the front sprocket) blow out of its spot in the case. I think trans case pressure is a factor in that happening. I have never seen a crank seal shredded though.
Old Jul 21, 2004 | 01:53 PM
Shav0's Avatar
It was tore up because once it came out of the bore it basically floated in the case and was ripped between the primary gear and the clutch.
Old Jul 21, 2004 | 04:10 PM
I am surprised it even ran long enough after the seal came out to tear it up.
exmotocrosser
Sep 13, 2019 06:12 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
