warrior rev limiter
Old Jul 28, 2004 | 01:56 PM
95warriorrider's Avatar
Default warrior rev limiter
i have a 95 warrior and i am wondering if there is anyway to get around the rev limiter. I bought the bike with a twist throttle installed. Any help would be greatly appreciated
Old Jul 28, 2004 | 05:55 PM
95Wolverine's Avatar
The only rev. limiter on a 95 warrior would be the throttle stop screw in the original thumb throttle housing. If you have an aftermarket twist throttle then you'll have to check it over very carefully to determine if there is any kind of adjustable stop to give the barrel a stopping point. If there isn't one, then when the slide in the carb reaches the top, that's all there is.
Hope this helps
Old Jul 28, 2004 | 06:43 PM
Warrior350ripper's Avatar
just curious what would happen if i were to take the screw out? would the engine blow or what
Old Jul 28, 2004 | 07:04 PM
95wolv's Avatar
The Warrior will float the valves before it revs too high to handle, the valve springs can only take so many rpms, then it will sputter and miss. Thats why a good set of aftermarket springs are needed when putting a cam in,so it can utilize the extra power and rpms of a hotter cam.
Old Jul 29, 2004 | 01:22 PM
thank you for the help ill have to try it. if you have anymore info plz let me know
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
