When I start my warrior why dose it smoke?
Old Aug 4, 2004 | 12:43 AM
Jordanw's Avatar
Default When I start my warrior why dose it smoke?
When I start my warrior it smokes for about a minute (until it gets warmed) up and then it’s fine, it only dose this when it hasn't bean started for a day. Any ideas on what this is or on how to fix it?
Thanx
Old Aug 4, 2004 | 02:21 AM
UltimateAussie's Avatar
my take on this is that when you first start it up the cylinder and plug are all cold still. and until it warms up the cylinder walls and the valves and all that good stuff. the engine is not at premo running temp so it doesnt burn as cleanly. but once it warms up it starts running cleaner.. but i dont think you can do anything about it, i dont think they make block heaters for quads
Old Aug 4, 2004 | 11:26 AM
OuterLimit's Avatar
Oil is getting past the valves, and being burned in the combustion chamber. As the engine warms up the valves seat better, and the oil burning stops. You might be able to fix the problem by being sure your valve lash is adjusted properly. Either that, or just don't worry about it since the problem goes away once the engine warms up. This is something that is actually quite common with that old tech Warrior motor, and also with the Wolverine motor.
Old Aug 4, 2004 | 02:24 PM
hondabuster's Avatar
What color is the smoke? Does it have an odor?
Old Aug 4, 2004 | 04:01 PM
Jordanw's Avatar
thanx, and ya its defenitally oil smoak
Old Aug 4, 2004 | 10:35 PM
SpDdEmOn's Avatar
Its possibly the rings if its oil smoke. Whats probably happening is that the rings are scored a little and it smokes when cold until the engine gets warm enough for the metal to expand and then the rings seat up good, hense the smoking going away. This could be a result of something as simple as no enough break in time before hard riding.
Old Aug 4, 2004 | 11:20 PM
hondaguy13's Avatar
the person who built the motor probably built it loose so when it is cold it smokes cause of oil getting burned and when it warms the rings seat better and it stops smokin and it is built loose so when the motor gets hot it is not as easy to sieze up
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
