raptor ignition?
Old Aug 4, 2004 | 10:21 PM
raptoric's Avatar
Default raptor ignition?
so i was running around local track and the rap just shut off!
checked wires ,fuses under seat ,battery is good
i do have kill switch but that looks good also
press start button and nothing happens not a sound
any ideas on where to look??
Old Aug 4, 2004 | 10:31 PM
04Raptor350Guy's Avatar
That is weird.... never heard of that happening before.
Old Aug 4, 2004 | 11:12 PM
white660Raptor's Avatar
i had a problem a week or so ago that it lost fire. the wires under the seat going to the ignition were rubbing together and wore the rubber coating off of each other and were grounding out or something. taped them up and it worked fine. not sure if this helps any but good luck with it anyways.
Old Aug 4, 2004 | 11:35 PM
raptoric's Avatar
ive checked wiring pretty good,
although i will run through it again
i was thinking maybe fuse i dont see or
something
im lost on this
Old Aug 4, 2004 | 11:45 PM
Ward660R's Avatar
Try and jump the starter relay behind the battery. Stick a rubber handled screw driver and touch it to both bolts.
Old Aug 4, 2004 | 11:54 PM
raptoric's Avatar
this is small piece with the two fusses in it??
if so i have noticed it bounces around
Old Aug 4, 2004 | 11:55 PM
raptoric's Avatar
am i trying to start the quad while touching two bolts?
Old Aug 5, 2004 | 12:07 AM
raptoric's Avatar
i did this and the quad started on its own. no key
what does this mean relay is bad ?
Old Aug 5, 2004 | 03:00 AM
RaptorOwner's Avatar
Sounds like it, does your lights come on?
Old Aug 11, 2004 | 01:19 AM
raptoric's Avatar
put the new starter relay and nothing same as before[img]i/expressions/face-icon-small-disgusted.gif[/img]
so anybody have any ideas??????
it will start if i jump starter relay but it dies as soon as i take off screwdriver
what the ffff
is there another relay somewhere??
i give up on this one
bmxatv10
Oct 14, 2022 06:23 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
