Steering play on Big Bear
Old Aug 11, 2004 | 11:46 AM
dgibbs's Avatar
Default Steering play on Big Bear
I can turn my handlebars approximately 1/2" left or right before the wheels start to turn. I used the search engine and found that a lot of folks with Raptors have had the same issue and have either tightened the nut on the bottom of the steering stem or completely replaced the factory nut with a castle nut. I'm wondering if the steering setup between the two are similar and if so, could this be my problem? Also, where exactly is this steering stem nut located?
Old Aug 11, 2004 | 12:47 PM
03250bayou's Avatar
i dont know the answer...but i have the same problem...not as bad as you though...mine turns very little...i think its getting worse though[img]i/expressions/face-icon-small-confused.gif[/img]....bump
Old Aug 12, 2004 | 09:27 AM
dgibbs's Avatar
Tightened the nut and all is well. I did remove the pin and add some loc-tite so with any luck, this will never happen again.
Old Aug 12, 2004 | 11:15 AM
Lomax's Avatar
Yeah mine was doing it so i took the steering stem nut off and filled it full of locktite, Problem seems to be solved for me.
bmxatv10
Oct 14, 2022 06:23 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
antiguogrumete
Sep 5, 2015 03:41 AM
