Drag Race Mod Banshee vs LRD 330R in 300ft
I raced in trail Mod and Won My class. But there was a real fast LRD 330R we were even out of the start and then he would pull about a Tire on me and then I would pull 1/2 Quad on him and take the win.
How should I send my Flywheel to to have it Lightened?
Ok here is what is Done to my Shee
FMF Fatty Pipes
FMF Power Core 2s
Cool Head w/21cc Domes
Race Logic Porting
Vitos Power Pistons
28mm Flat Side Carbs
V-Force Delta 2
Vitos Degree Key
Boost Bottle
Team Alba Clutch Kit
Hinson Clutch Basket
Hinson Cushion
Hinson Pressure Plat
Pro Flow Intake
6 Filtered air vents
Mod still to come Lightened Flywheel and a +4 Stroker Crank.
And when I am drag racing I run stock Gearing.
He had
330R Big Bore
ESR TRX11 Centermount pipe and the ESR Silencer
ESR 41.5 cARDURETOR
TRX Air fiter kit
RB2000 Billet reed Blocks
Wiseco Crank
Barnett Clutch kit
And was the only one with a quad Motor that could beat him
FMF Fatty Pipes
FMF Power Core 2s
Race Logic Porting
Vitos Power Pistons
V-Force Delta 2
Vitos Degree Key
Boost Bottle
Hinson Cushion
Pro Flow Intake
He had
330R Big Bore
ESR 41.5 cARDURETOR
TRX Air fiter kit
Wiseco Crank
Barnett Clutch kit
Hey FMF, there is still lot's left in your Shee. Our std bore pump gas shee's (with our trail porting) run mid 5 sec in 300ft with fatties and our 382's trail package with high compression run low 5's high 4's. Our 472 EX's on pump gas runs 5.5's-5.6's and our heavey V force 785's on pump gas run low 5's.
PS: our pump gas YFZ's are running low 5's in 300 to.
Keep testing, if your porting is decent at all you'll pick up a half sec easy.
Dynoray
Dynoray
It will run faster then 6.033. The track was hard to figure out the start has Rock hard and the about 200ft it would get soft Like Clay and then it would get hard again. And the track was like Fine crusch stone. But on Dirt It will run 5.4s
Try advancing you timing while you at the fly wheel . Its an easy 2hp
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
