yfz seems to have lost power... (updated)
Old Aug 23, 2004 | 05:06 PM
Hozed's Avatar
Default yfz sems to have lost power... valves???
Originally posted by: stevendsm95gst
time for new rings?
that was my first thought.... but it starts right up and seems to run fine... i was told to check the vavles first.
Old Aug 23, 2004 | 06:23 PM
patient's Avatar
hi does anybody know the specs for these valves. Thanks
Old Aug 23, 2004 | 07:24 PM
briansgi's Avatar
Originally posted by: Hozed
the past 2 times ive been out riding it just doesnt have the same power... i am hoping its the valves... i am told they tend to tighten up on these type of motors which would explain why i cant here them tapping... anyone else got some input???
it revs and starts up fine... but the power just aint there like it was.
Clutch possibly slipping??
Old Aug 23, 2004 | 08:49 PM
thunderalley400ex's Avatar
Even if it starts up fine it could still be fried rings. That is probley your problem...
Old Aug 24, 2004 | 02:41 AM
  #15
Trinity748's Avatar
How could the rings be gone already? he has only had it 5 months... That does'nt make any sense that the rings would be so worn at this point, unless there was a defect of some kind. Although i'm not sure what that would be.
Old Aug 24, 2004 | 03:14 AM
  #16
deathmetal's Avatar
How many hours do you have on it? Compression check?
Old Aug 24, 2004 | 07:13 AM
  #17
Hozed's Avatar
i am going to my dealer today... i tend to ride up near the rev limiter ALOT... so rings wouldnt surprise me... but i was told by a few guys who run dirtbikes that vavles will do the same thing... who knows...
Old Aug 29, 2004 | 09:10 AM
  #18
Hozed's Avatar
ok, ive checked my valves... intake needs to be between .004 - .006
i can just barely fit a .004 in them... and the exhuast needs to be .008 - .010 i can just barely fit an .008 in them.
the gauges slide in very tight and it take some wiggling on a few on them... but IMO this isnt off enough to make to much of a difference.
any input?
and if anyone knows how much compression these things are supose to have could you let me know, thanks.
Old Aug 29, 2004 | 10:33 AM
  #19
Ernie660R's Avatar
Default yfz seems to have lost power... (updated)
Well because of the decompression pin you still should build up to 120psi to 140psi if you have more than that its not the rings.
lonerider856
Oct 13, 2023 03:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
bigbear350quad
Sep 11, 2015 12:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
