Yamaha Warrior - HELP
Old Aug 23, 2004 | 03:49 AM
confederateYamaha's Avatar
Default Yamaha Warrior - HELP
[2002 Yamaha Warrior]
I have a problem! This warrior is in perfect condition, with excellent compression. However, when I put it in forward, or backward -- it will not go anywhere! No matter what gear I have it in... It starts great... ........just wont go into gear...
Any ideas on what the problem is? Thanks
brandon@americandf.com
Old Aug 23, 2004 | 08:53 AM
JakalWarrior's Avatar
Need more info. Does the tranny engage but the clutch not catch, will it not get in gear, does it make any noises etc....
Old Aug 23, 2004 | 10:08 AM
NLWarrior01's Avatar
Yeah, your problem discription is a bit vague.
Sounds to me though that either your clutch needs replacing or adjusting. A buddy of mine has a similar problem with his 2001. With the clutch adjusted so that the machine moves, it jumps when you put it in gear and going into and out of reverse is a pain. Getting into neutral is also troublesome ... I over adjusted his clutch to where it was shifting without much jumping and going in and out of reverse with no probs .. but then the machine wouldn't move .. LOL
Does anyone have any ideas on why the Warriors seem to be so damn hard to get into neutral when they're running hard? If I'm spinning around a sand pit and doing jumps and such if I come to a complete stop and try to shift into neutral it simply will not go. I can shut the bike off and do it easily, or shift into neutral while I'm coasting to a stop .. but doing it from a dead stop .. nuh uh ..
I don't have the same problem while trail riding though ..
Old Aug 23, 2004 | 10:43 AM
ss97's Avatar
Lets Ride!
Well I agree that they are a notchy tranny.
What works well is if you rock the quad back and forth with the cluth pulled in. I don't know if it's because it's an old-school design or what. But I learned the trick from a buddy who has been racing 2-wheeled MX bikes his whole life. He has to do it all the time on his MX bikes.
The Warrior is the same way. Sometimes you just can't get into neutral or reverse, so you gotta pull the clutch and literally move the quad back and forth a couple time while tapping down the gear shifter and pulling up on the shifter until you can feel it click into 1st or 2nd, then you can find neutral. It's almost like something gets jambed in there. It also helps if you find neutral before you come to a complete stop, then click it into 1st after you stop.
Old Aug 23, 2004 | 01:50 PM
Sometimes when you put it into gear, you can barely hear a clicking noise. For example, like it's not catching on the chain or something..... just click click click click click....
Any ideas now?
Old Aug 23, 2004 | 01:58 PM
While letting out on your clutch gently, push the reversing lever forward. Mine does that sometimes, so now I just feather the clutch while putting it back in forward.
Old Aug 23, 2004 | 02:30 PM
I just tried to make the clutch more tight / lose... Nothing. When I slowly put the lever (Forward/backward) I heard a much louder click. This isn't the click I was talking about.
** I had it in neutral, and just put it into gear. It jumped for a split second, but wouldnt proceed with movement. It's as if it's not catching. Keep in mind the engine was still on after it jumped.
Any ideaS? ...the dam quad wont move. :-o
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
