How to clean the carbs on 2 strokes???
Old Aug 23, 2004 | 04:49 PM
limitdedsheerider's Avatar
Default How to clean the carbs on 2 strokes???
Can someone please tell me how I should go about cleaning the carbs on a 2 stroke engine?
Maybe include a tool for cleaning if any and a liquid or some type of cleaner or lubricant, motor oil/gas/ect.
It would be very much appreciated because I am alot better rider than I am mechanic so im trying to learn a little to help even my skills out...
Old Aug 23, 2004 | 04:54 PM
Shav0's Avatar
You can pick-up some carb cleaner at a local shop, that usually does the trick. They are pretty basic to remove and re-install so you shouldn't have any major problems.
Old Aug 23, 2004 | 04:59 PM
Would anything else work that I may have laying around the house other than actual cleaner?
Old Aug 23, 2004 | 05:02 PM
ketchupYFZ450's Avatar
I wouldn't just going spraying household cleaners into your carb., buck up and buy a can of carb. cleaner, it's like two dollars!
Old Aug 23, 2004 | 05:04 PM
2 bucks? ok bill preciate it
Old Aug 23, 2004 | 09:12 PM
lemonade's Avatar
a good can of ether (starting fluid) will do the trick and spray through every part of that carb. even let sum settle in ur carb bowl for a little bit.
Old Aug 23, 2004 | 09:18 PM
Blaster96's Avatar
My advice would be to take the whole thing apart. Remove all rubber and the floats. Hose it down with B12, then add some compressed air.
kelleycully
Sep 15, 2016 02:57 AM
honda71
Jul 12, 2015 05:56 AM
Jul 7, 2015 11:00 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
