Burning oil?
Old Aug 23, 2004 | 06:15 PM
05raptorguy's Avatar
Default Burning oil?
Hey all,
Im still new to riding and such, just got these bikes new. Anyways when I start them (cold) they smoke for about 10 seconds then stop. When I was running them the other day opened up, I noticed smoke again at about 40 mph. maybe faster not sure. Anyways, is this normal? The reason I ask is that if it isnt, they are still under warranty. Thanks a ton!
Old Aug 23, 2004 | 06:27 PM
warwgn's Avatar
what color is the smoke?
Old Aug 23, 2004 | 07:04 PM
Its kinda blueish and smells like burning oil for a little bit.
Old Aug 23, 2004 | 07:35 PM
warpigs's Avatar
Did you allow the motor to break in before you panic. Allow at least 25 hours, mabe more because the motor is brand new.
Old Aug 23, 2004 | 08:10 PM
Well the motor has something like maybe 10 hours on them total. Ive changed the oil once. So this could be break in?
Old Aug 23, 2004 | 08:45 PM
warpigs's Avatar
Yeah let it go for at least 25 hours, after that I would start to worry.
Old Aug 23, 2004 | 08:50 PM
warpigs's Avatar
The way I was told to break mine in was to run it as hard as you want but not for extended periods of time. Run it for while, get it real hot, then rest it for a while and let it cool down real good. This has somthing to do with the hot and cold cycles of a brand new engine. With a rebuilt engine you don't have to this.
Old Aug 23, 2004 | 09:27 PM
ahh i see thanks for the tips! I got another question. I looked at the air filter and it was dirty so am wanting to clean it. Read to use soapy water is one way so i took it out and am soaking it in soapy water. Will this work?
Old Aug 23, 2004 | 09:39 PM
Turtler's Avatar
First, read the owners manual on how to break in your motor, yamaha knows best how to break in their motors. Regarding cleaning your foam filter, get some foam filter cleaner and foam filter oil, for example PJ1 makes both. Ive tried the soap and water versus the PJ1 solvent, the solvent method is easier and cleans better than soap and water.
Old Aug 23, 2004 | 10:10 PM
Everyone seems to have a different way to break stuff in. Just want to make sure everything is running ok. I did pull my plug and it is black so it seems things might be running a bit rich as well.
