Raptor Engine Clatter
Old Aug 24, 2004 | 08:53 PM
MasterRaptor's Avatar
Default Raptor Engine Clatter
I just installed a 686 kit with a stage 1 cam. I am getting a clatter from the area of the cylinder.
I can't figure out what it is with out pulling it all down again. Anybody ever have this problem? Any suggestions?
Thanks!
Old Aug 24, 2004 | 09:01 PM
pinheadedjoker's Avatar
Is it a clatter of the valves with teh new cam? Mine clicks a bit but thats normal.. is ur jetting good?
Old Aug 25, 2004 | 11:44 AM
Pinheadedjoker
I am hoping it's the clatter of the valves. I set the lash to yamaha's spec intstead of hot cams to see if it quieted dowm. It didn't make much of a difference.
What is your valve lash set at?
Jetted at 165/170...Dynojet needles...open airbox...ported...full exhaust. It runs great.
Old Aug 25, 2004 | 12:12 PM
warwgn's Avatar
are you certian your cam gear bolt are tight, i have done that before just got them finger tight and forgot to go back and finish it untill I already had it all back together, and it clattered like what you are describing.
Old Aug 29, 2004 | 10:58 PM
1LeSSRaptor's Avatar
Masterraptor, what do you have into the motor? I was just asking because I was jetting mine right now for the billet adapter with out the airbox, K&N, and the Eseries slip on and was trying to get an idea on what I should start with. It really threw me off though when I looked at your jetting and warwgn's jettiing. I know he is running the 686, but even if you are too, why are your jets so much bigger?
Old Aug 29, 2004 | 11:45 PM
warwgn's Avatar
I'm at just over 5000Ft, and I am still in the process of getting the jets dialed in, I have been messing aroud but I got to fix the oneway before I can do more!!
Old Aug 30, 2004 | 12:57 PM
1LeSSRaptor
It's 686, 11:1, ported, stage 1 cam, big gun full exhaust, K&N Pro with no airbox lid, dyojet kit.
When you remove the air box lid, the jet size really needs to jump up because the air box chokes the flow bigtime.
I am running the main jets at 160/165 for 6000ft, 165/170 for sea level. My needle is in the middle position, but I think it needs to be leaned a position or two.
Old Aug 30, 2004 | 02:13 PM
warwgn's Avatar
I'm at 12:1 and stage 2 cam, I plan on goin up on the jets when I can start it again, I broke it in with 165/170 and it ran great on the top but the plug was black, but I have messed with the pilots and needles since so like I said still got more work to do!
Old Aug 30, 2004 | 05:06 PM
garyc660R's Avatar
165-170 is on the lean side for your set-up at sea level...IMO. A lean condition means a hotter running cylinder...which facilitates DETONATION if you are not running higher octane fuel.
Gary
Old Aug 31, 2004 | 12:04 PM
I was wondering if 165-170 is lean at sea level. My plug is white. But, it sputters like it's rich in the mid range.
Lean the needle setting?
