Valve Adjustment
Old Aug 27, 2004 | 09:44 AM
lvl1trauma's Avatar
Default Valve Adjustment
Fellas,
How often is valve adjustment recommended for the Grizz 660? How long should it typically take?
Thanks,
Lvl1Trauma
Old Aug 27, 2004 | 10:53 AM
HoundDog06's Avatar
I like to check them about every third or fourth oil change (I change my oil about once a month). It takes about 30 to 45 mins from start to finish. Most of your time is spent removing and replacing plastic.
~HoundDog
Old Aug 27, 2004 | 11:34 AM
lvl1trauma's Avatar
Roger that. Thanks for the info. I am about to indulge in a camo 660. It is down to it and the AC650. The Grizz winds hands down in the clutch/trans. department. It is going to be a little cheaper as well. I also like the overall setup. I would get a Bomb. 650 but they don't make an IRS that big. I want something bigger than the 400 they offer- it is a fine machine for a flatlander, though.
Thanks again,
Lvl1Trauma
Old Aug 27, 2004 | 11:41 AM
HoundDog06's Avatar
I would recommend the grizz. I have no faith in Arctic Crap after rebuilding about six of them from the ground up. I feel like they are buying a cheaply designed motor (from suzuki) and placing it in a poorly designed frame. My only complaint towards bombardier is the expense of their parts. I don't know if its just this area or what but bomb parts are expensive as hell here.
~HoundDog
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
