got spark,got fuel>no spark!
Old Sep 1, 2004 | 09:44 PM
cb239's Avatar
Default got spark,got fuel>no spark!
99 warrior have fuel,have spark,but it wont kick over not even a putter,
Old Sep 1, 2004 | 09:50 PM
UltimateAussie's Avatar
compreshion? i am not sure i have had this problem before and it was a stuck valve you might want to check them
Old Sep 1, 2004 | 09:57 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
put it in gear get on it and shake it to hell... soemthing in your starters going out...
Old Sep 1, 2004 | 09:58 PM
Speedy2222's Avatar
it's teh gear it's sticking.. idk what the name of it is.. it happened to my friend 89 430 big bore..
Old Sep 1, 2004 | 10:48 PM
cb239's Avatar
i put a new plug in, i chock it crank it for 10 secs,pull the plug,it seems dry,,the bike has good compression,
Old Sep 2, 2004 | 12:31 AM
hondabuster's Avatar
So... the motor will spin over...it just wont start?
Hows the valve adjustment?
How did the spark look? strong?
Have you tried a new plug?
Old Sep 2, 2004 | 09:28 AM
cb239's Avatar
Yes it spins over but wont start,the spark is there but kinda weak, It is a new plug, Iam checkin the valves today,seems pretty easy to check,maybe the intake is to tight,it was running ok saturday,turned it off,and after restarting it,it poped throught exhaust,at 1/4 throttle AND UP,gonna also c if it will run on starting fulid,
Old Sep 2, 2004 | 10:23 AM
I know this sounds basic...are you running out of gas? Try going to reserve, or add some gas to the tank.
Old Sep 2, 2004 | 10:33 AM
cb239's Avatar
HEHE,i added gas to it already thinking the same thing,also went to reserve,it didnt start on either,yet the pulg still sparks,but it was dry,the valves look ok also,just doesnt make any sence>i set the timing mark to the | line to check the intake,valve it is ok,very strange deal i seem to have,other then the spark being weak,everything else seems ok,what else should i do
Old Sep 2, 2004 | 10:59 AM
cb239's Avatar
here is the big question on the spark issue>it has asmuch spark as a gas grill ignitor,is that enought spark?
