Are Raptor Frames this weak?
jdmj23.. My frame is bent on the front of the raptor.. kind of where the steering stem connects to the frame.. Its worse than yours cause my front end shakes when im riding fast. RPM does make a subframe and im not positive but ill say its about 400- .... Did you ever get that brake recall from yamaha? Maybe your caliper is bent a little and when the piston brakes it cant retract to let the disk free... just a thought. If you find a new frame or if your dealer is sellin one tell me the price cause i deffinatley need a new frame.
Raptorboy, yeh I got the recall done the 1st time they locked up. You might be right about the caliper, I've been telling the dealers everytime that it's the last thing that hasn't been replaced. For some reason though the dealer acts like it's coming out of their pocket to replace it. You could be right though because it's heating up as if though it's not releasing and the brake pedal becomes hard due to the fluid basically boiling past it's boiling point (DOT4). You can order the frame from any yamaha dealer, you just have to order it and I'm pretty sure it was about 650 give about 20-30 bucks ea. way. You should be able to call your yamaha dealer and they should tell you the price. It should be the same price anywhere because of it being right from Yamaha. I'll look for an aftermarket frame though.
Thanks
Thanks
#15
I took mine to a local atv shop to have it straightened here in Phoenix called "Screwie Lewies" after it tumbled down a mountain. (You ever seen a Raptor cry? I did.)
They straightened the aluminum sub frame and the main frame around the steering stem area. They did a pretty good job. They cold bent everything back to about 95%. You can't really tell that it is tweaked 5% unless you are looking for it. They only charged about $100.00
This was 2 and a half years ago and haven't had any problems since.
You could call around to motorsport shops in MI to see if they do it.
#16
#17
Originally posted by: Yamaha660R
No sport quad can take hard crashes into tree's, or long rolling flip's off hill climbs. They aren't designed to ride you. [img]i/expressions/face-icon-small-wink.gif[/img]
#18
#19
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
