Lone Star Question
Old Sep 4, 2004 | 01:53 PM
LivinInVegas's Avatar
Default Lone Star Question
Anyone know how tight the nuts on the Anti-vibration clamp should be? Is there a torque spec, I don't want to damage the rubber gromets?
Old Sep 4, 2004 | 03:02 PM
Loadtoad84's Avatar
How hard was it to swap out that stem? Did you get a "standard" length stem? If so is it any longer then the stock one? Just curious, I've been thinking about getting one. Sorry I can't help ya with your torques... Can't go wrong with the ole German Torque, you know, Gootundtight[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 5, 2004 | 01:33 AM
Swapping it out was no problem, take off the front plastic to get to the bolts in front of the gas tank that remove the upper clamp. You have to pry the tabs back on the bracket that keeps the bolts from coming loose though. You''l see what I mean. When you put in the new stem it's about 1" taller then standard with the anti-vibration clamp so you will need a low rise bar for the stock cables to work. I got a CR style bar and it's perfect. I say go for it. it's a great stem kit.
Old Sep 5, 2004 | 04:19 PM
Loadtoad84's Avatar
Hey thanks man, hope you get your torque values.
Lt84
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
