Warrior creaking noise
Old Sep 9, 2004 | 07:58 PM
jdulac's Avatar
Default Warrior creaking noise
When i move my warrior back and forth with my handlebars i hearing some kind of creaking noise. And ofcourse when i'm riding i hear the noise also. Its only when you move it side to side. Nothing when you just push on on the front or back. I can not for the life of me find out where this noise is coming from. Does anyone have any idea where the noise could be coming from. I've got the airbox off so that i can better access where i think the noise is coming from. I also lubbed all the fittings. It just started making this noise. TIA.
Old Sep 9, 2004 | 10:20 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
ypu knopw i have that noise but ONLY when im stopped or slowly moving... i can't figure it out either... i TRULY think it's the shocks or the a arms(bushings)
Old Sep 9, 2004 | 10:41 PM
bvwarrior's Avatar
i think it is almost for sure your steering stem, mine does it, it creaks where the bearing is half way down, but mine also creaks at the swing arm bearings, and if not greased right at the shock linkage
Old Sep 10, 2004 | 12:13 AM
rcnitro's Avatar
my kodiak did that sprayed some wd40 on handle bar post (neck) ik guess it is called and mine stoped
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
