Broken Shock Again!!!!!
Old Aug 23, 2000 | 07:53 PM
Kid_Warrior's Avatar
I have a 99 warrior and keep busting the front shock so for i busted the shocks on both sides and now the right side busted again. The first two times it was a defected weld and warrenty covered them. Has any one else had any trouble with there front shocks on a warrior? Do u think warrenty would cover them. And so fare every thing on the piiece of S**T is defected like the tranmission cases and crab and i am getting fed up with it!!!
99 warrior
Old Aug 23, 2000 | 07:58 PM
BansheeBill's Avatar
Either you have extremely bad luck with your suspension or you need to assess you riding characteristics and modify your bike accordingly.
Old Aug 23, 2000 | 08:05 PM
I hardly ever bottom out when jumping and when they lost all they fluid in them i was just putting from my house to my uncles throught the lawn.
Old Aug 23, 2000 | 09:34 PM
PC_350_Warrior's Avatar
I busted my right front near the bottom. I took it to the Yammy place and they welded it. I believe why mine broke was from the angle the shock kept going to. I had it on the 2nd stiffest setting and I was jumping big and it would bottom them out and put the shock in a angle it shouldnt go to often. Anyways, after they welded it I pumped it up to the stiffest and it works great now. I've been thinking about getting Works Shocks now tho!
Old Aug 26, 2000 | 09:00 PM
warrior007_2's Avatar
dump those stockers they suck bad. mine worked like pogo sticks, hardley any rebound damping. i got works now, problem solved.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
