banshee replacement reed valves????
Old Aug 24, 2000 | 12:38 AM
NWscramrider's Avatar
i am considering putting a new reed valve set on my banshee. my question is which one will give me the best bang for my buck. i've heard good things about boyseen rad valve , carbon tech, or delta v force valves.
Old Aug 24, 2000 | 11:08 AM
BansheeBill's Avatar
According to the dyno's that I have seen, the V-Force Delta 2 reed cage/reeds seem to be the only only setup that lives up to it's advertising.
Old Aug 24, 2000 | 02:26 PM
banshee97's Avatar
i put the delta v force 2 in my 99 banshee and it made a big difference and then when i had it rejetted they went up 6 sizes and wow it made a bigger difference yet i went from 280 mains to 330 mains
Old Aug 24, 2000 | 06:07 PM
garyc660R's Avatar
You went from 280's to 330's just from changing reed cage/reeds?
Old Aug 24, 2000 | 06:09 PM
garyc660R's Avatar
NW..have you already installed pipes? If not, the best bang for the buck is the pipes/silencers.
Old Aug 24, 2000 | 07:49 PM
banshee97's Avatar
all i have done to the banshee motor is a cool head with 21 cc domes, got rid of the tors system, fatty pipes and power core silencers a unifilter i had all that done and they rejetted it to 280 mains and then i put on the delta force 2 reed cage and they rejetted it to 330 mains and i am running it on 93 octane fuel i had the dealer ship that i bought the bike from do the jetting work
Old Aug 24, 2000 | 10:13 PM
Gary 660,, i have fmf fattys and turbine core silencers with 2 k and n filters and re jetted to 290's, just looking for a little more, thanks.
Old Aug 25, 2000 | 01:10 PM
Rob4092's Avatar
Are the Delta V Force Reeds really worth the $230.00 they cost?
Do you get that much performance improvement to justify the $$$$?
How difficult are they to install and do they require any modification or do they slip right in?
Old Aug 25, 2000 | 01:41 PM
The performance gain from the V-Force reeds is definitely not worth $230 or even $50 if you are an average rider. If you compete with other riders and are constantly looking for an edge, the V-Force reeds can supply that. They do add a small amount of hp but don't have the smile producing impact of adding an aftermarket head or pipes. To some people having this edge may be worth $230.
As far as installation, on the intake manifolds you must cut off the flanges that extend into the stock reed cage in order to install them on the V-Force cage. Otherwise the installation is no different from the stock procedure.
Cole Hadden
Jun 15, 2025 09:05 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
