Wolverine axle lube?
Old Aug 24, 2000 | 12:20 PM
MDP49's Avatar
I don't have a book and I need to change the oil and grease in the drivetrain. What type of oil do you put in the differential of a '00 Wolverine? Do you pack the bearings with any type of special grease, like marine grease? Thanks.
Old Aug 24, 2000 | 01:22 PM
DOO800's Avatar
MDP49-
For the rear end,good gear lube (90w) will work but the front needs limited slip fluid, also DONT overfill either pumpkin it will spit the fluid out the vent lines -- up near the carb!!!The bearings are not greasable except to remove the seals and manually grease them.
Good luck,
DOO800
Old Aug 24, 2000 | 02:07 PM
Harold's Avatar
You can grease the front bearings with a grease needle or drill and tap the steering kunckle and install a grease fitting.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
