Back fireing in my banshee,any help??
Old Sep 18, 2004 | 08:31 PM
wilson750's Avatar
Default Back fireing in my banshee,any help??
This is what FMF says: It says to take off the air box lid snorkel,Soo i guess there will be no lid for the airbox then..Anyone is that correct? But i guess i do have the correct size jet..I just got this banshee, soo anyone who seems to know alot about them would be a great help..thanks
Jetting Information
Main Jet: 260
Pilot Jet: 30
Needle: STOCK
Needle Position: 3RD
Power Jet: N/A
Air Screw: 1.5
Fuel Screw: N/A
Comments: Remove airbox lid snorkel
Old Sep 18, 2004 | 09:59 PM
raptor8738's Avatar
no you just take the snorkle. the hose lookin thing that runs up from the lid
Old Sep 18, 2004 | 10:08 PM
SuzukiRider3698's Avatar
heres what u do on ur carbs there are air and gas screws and if one is of it will prob make it back fier and run like $hit only on one side . and for it air take the lid of ur air box and drill about make 9\16 size holes about 4 on top move down about an inch and 4 more hole and u should be set
Old Sep 18, 2004 | 10:20 PM
wilson750's Avatar
The guy befor me cut hole sin the airbox lid..just like you said..I turned each air screw out 1.5 turns..If it had bad reeds would it back fire?as for the gas screw? where is that located on the carb? inside or outside?
Old Sep 19, 2004 | 11:21 AM
  #15
my bad i think the air and gas screw are thed same thing atleast thats what i was told so that screw determins how lean or rich u run it
Old Sep 19, 2004 | 11:24 AM
  #16
for the reed thing take them out both of them and soak them in gas for about 2 hours and then spray some card cleaner on and when its spotless put it back it. it couls also be the left side of ur wireing that hooks on the spark pulg if u know how to cheack that then that will tell ya
Old Sep 19, 2004 | 11:27 AM
  #17
i looked on a site and it said the (neddel piston) should be on the 3rd i have no clue what that mean but if one carb it different then the othe it will deffenlty do something
Old Sep 19, 2004 | 01:06 PM
  #18
Sandfox24's Avatar
What kind of air filter do you have (K&N or Foam). This will make a difference in your jetting. There has been alot of quessing going on. Try to only do one thing at a time. Your air screw will not adjust the backfire out. Go through your carb completely.
Old Sep 19, 2004 | 02:31 PM
  #19
wilson750's Avatar
Ill try doing that with the reeds and see what happens..
bzdok1234
30
Feb 23, 2016 01:55 PM
Jul 7, 2015 11:00 PM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
