Banshee still runnin like poop!!! HELP!!!
Old Sep 22, 2004 | 10:36 PM
wilson750's Avatar
Default Banshee still runnin like poop!!! HELP!!!
Well My banshee is still runnin like Sh*%!!!! I have taken the carbs off sooo many times and cleaned them and checked the reeds...It still is breaking up and backfireing..
What should i do? any help?
I was going to buy a set of used carbs off EBAY...Since i think mine r junk..That is the only thing i can think of doing!!!
If anyone has any help, please help me out....[img]i/expressions/face-icon-small-mad.gif[/img]
ALSo: Does it matter if the tube that goes behind the choke and goes to the other carb isnt connected? It was there when i bought this quad..please help!!
Old Sep 22, 2004 | 10:55 PM
AustinONeal's Avatar
i found out with a kfx400 that if you dont have all the breather hoses and the all the lines hook up in their orignas position it will pop like you talking about
Old Sep 22, 2004 | 11:00 PM
wilson750's Avatar
Thanks.. maybe thats it..Also the choke doesnt stay out when u pull it.. Donno whats going on with that also..
Think i should just junk these carbs? anyone?
Old Sep 22, 2004 | 11:59 PM
the choke not staying out my blaster does the same thing nothing to worrie about there
Old Sep 23, 2004 | 02:34 AM
bad350twin's Avatar
that little tube in between the carbs is your problem.... i went through the same situation!
Old Sep 23, 2004 | 03:31 AM
Sandfox24's Avatar
The tube that connects the two carbs is to choke the 2nd (right side) carb, since it doesn't have a ****. I have forgot to put it on before and it didn't run very well.
Sometimes you have to start replacing parts. I would buy a Rebuild Kit for them.
Old Sep 23, 2004 | 10:26 AM
sAyIt_fmf's Avatar
You need to hook that line up between the carbs....
The choke not staying out is a common problem with banshees...the groove that holds it in place gets worn out. It should be fine...you just need to hold the choke out till the bike warms up. A replacement choke costs around $40.
Old Sep 23, 2004 | 02:26 PM
DrDune's Avatar
get a YFZ450 [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 23, 2004 | 03:35 PM
AlkyBurninX's Avatar
Another vote for that tube. Been there, done that WAY to many times.
Old Sep 23, 2004 | 03:43 PM
SexySkaterShane's Avatar
edited by ATV connection moderator
Please stay on topic
