performance mods for the blaster
Old Sep 25, 2004 | 10:22 PM
blasterfool's Avatar
Default performance mods for the blaster
hello evereyone. i just picked up a 05 blaster and have a few questions for ya. i want to gain some more power in the low end. i don't race or compete. just ride trails and sand.
i noticed that my blaster will bog down in the sand and i have to change gears. what kind of mods can i do to help me out.
BTW this is my 1st ATV so if your saying i should have got something more powerful then the blaster the reason i didn't was cause i wanted to learn on something without breaking bones.
i see a lot of people change exhausts. is it really worth the money? or how about switching to a K&N filter?
help me out. thanks.
Old Sep 25, 2004 | 11:54 PM
MTX's Avatar
MTX
B1 Toomeys,K&N Filter,Changing Sprockets for dunes and good paddles (skat trak).
Old Sep 26, 2004 | 12:11 AM
where are you guys buying parts? i guess a B1 toomey is a exhaust, right. why is that better then others?
Old Sep 26, 2004 | 12:15 AM
yamaharider200's Avatar
The first thing to get is an aftermarket air filter and maybe some reeds. Aftermarket pipes make a big difference. If you want low end power then the Trenga/LRD pipe kit is a good choice. Procircuit also gives you a lot more low end. It is usually better to buy a pipe kit rather than just the pipe and silencer because in the pipe kit you get perfect jetting for that pipe setup, all the hardware you need, and sometimes the pipe kits come with an aftermarket air filter.
Old Sep 26, 2004 | 12:18 AM
The Toomey B1 pipe kit is a great kit but it adds midrange and top end power and doesnt really give you anymore low end power which you said you wanted
Old Sep 26, 2004 | 05:46 PM
zorg43's Avatar
Exchaust pipe not worth the money. If you want to wake up the blaster port and polish the motor. If you don't want to do that then try- better air filter,reeds, change gearing, 18 " tires in the back. Pipes are ok but it's not going to give you what your looking for.
Old Sep 26, 2004 | 07:35 PM
Shav0's Avatar
Not true. Changing out the pipe is usually the best mod to do first. You can port all you want but your still going to be held back by the exhaust flow. Adding a higher flow air filter won't do anything unless you have the exhaust flow to go with it.
Old Sep 27, 2004 | 10:42 AM
CmyBackULose's Avatar
Check out www.projectblaster.com
There Phantom pipe gives the blaster awesome low and mid range power.
Old Sep 27, 2004 | 07:17 PM
blastymaniac's Avatar
Pipe it and have the head milled to get more compression.
Smokin Joe
Old Sep 27, 2004 | 07:33 PM
FdaDOT200's Avatar
I have an FMF pipe on my blaster and it is awsome. I think the Toomey is better and prolly the LRD also, but i like my FMF. Also i put a wiseco piston in it and bored the cylinder 0.20 and i noticed a difference there as well. I heard that Boyesen reed are also real good for low end. Also you can port and polish that puppy, theres a lot you can do to blasters. If you want to get the thing real fast......just drop a 240 in that sucker....lol
