blaster rear brake help please
Old Oct 2, 2004 | 08:13 PM
quadfever54's Avatar
Default blaster rear brake help please
rear brake stops good but the pads do not release. you have to hit the rotor to each side to free up the rotor. any suggestions
Old Oct 2, 2004 | 09:36 PM
Shav0's Avatar
The stock blaster brakes suck big time. I had the same problem. Some of it has to do with the design. The release inside isn't very good and usually sticks. But for the most part, the problem is the parking brake. The cable that runs to your back brake also goes to the handle bars for the parking brake. It's this long cable that is most of the problem. Motion Pro makes a cable called the "shorty" blaster cable that eliminates the parking brake and makes it so you only have a cable that goes from the pedel to the caliper. It dosn't totally solve the problem, but it does help.
If you have the cash then you can always get a hydro brake set-up..They work really well.
Old Oct 3, 2004 | 12:27 AM
THANX FOR REPLIES, I TOOK IT ALL APART AGAIN, BEEN 4 MONTHS, AND SEEMS SOME MOISTURE CAUSED SOME CORROSTION. CLEANED IT ALL UP AND IS WORKING GREAT!!!! DID HAVE A HEADACHE BECAUSE IT TOOK ABOUT 8 TRIES TO GET IT ADJUSTED RIGHT.
THANX FOR THE REPLIES. NOW ON TO MY BANSHEE GEAR SHIFT PROBLEM. IF ANY OF YOU ARE EXPERIENCED WITH BANSHEE'S LOOK FOR MY POST ON BANSEE SHIFTER HELP !!!!]
LATER
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
315blaster
Aug 8, 2015 08:13 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
