Raptor shocks on a warrior, will they fit?
Old Oct 11, 2004 | 10:44 AM
SlueFoot's Avatar
Default Raptor shocks on a warrior, will they fit?
Does anyone know if it is possible to swap stock front raptor shocks to a warrior?
Old Oct 11, 2004 | 01:28 PM
maddog56's Avatar
They will swap and the suspension will be better but I'm not sure if the length will be the same, the raptor shocks may be longer.
Old Oct 11, 2004 | 06:35 PM
Boxhead's Avatar
Someone did it on this forum, and it worked alright. You will need to compress the shock a little to make it fit. It will make the suspension a little stiff however, but the stockers on the warrior are stiff as a board anyway. I weigh around 130, and when I placed +2" a arms on it with the stock suspension it was perfect for trails and small jumps. If a set of a arms is cheaper than the raptor shocks do it up, it will make your warrior much more stable, and with more travel.
Old Oct 12, 2004 | 09:26 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
i put 02 raptor fronts on mine works great.. the only prob i had with installing them is trying to get it just right so i can get the bolt in ( 2 or 3 man job) and it'll prolly cost u up to $70 to get yours hands on a pair
Old Oct 12, 2004 | 09:27 AM
Speedy2222's Avatar
the only shocks i know for sure work are 02 fronts 01 rear
Old Oct 12, 2004 | 12:36 PM
NLWarrior01's Avatar
Originally posted by: Boxhead
... It will make the suspension a little stiff however, but the stockers on the warrior are stiff as a board anyway...
I find the stock suspension on the Warrior to be really soft myself ... I weigh in full dressed under 175 .. most summer riding I do would probalby have me under 170 .. Very comfy ride I've found it to be.
Old Oct 13, 2004 | 09:16 AM
Speedy2222's Avatar
^^^^ you've OBVIOUSLY never riden a raptor or a warrior with raptor shocks... socks up alot more bumps than the stock warrior shocks
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
