Ice Racers Please Read!!
Old Oct 11, 2004 | 12:10 PM
jerstilly's Avatar
Default Ice Racers Please Read!!
I am going to be starting ice racing this winter and i just had a few questions about tire sizes. I am going to be going with the cheng sing ice tire along with kold kutter studs(i think). should i stick w the 20" tire on the rear or should I drop to an 18" tire. Also what rim size should i run. I will be buying an ice tire package w .125 aluminum rims. How many studs per lug should I be putting in and how long of studs..thank you very much..also if i change the rear to an 18" what should I go w on the front tires?? The available "rear" tire and rim package sizing are as follows :
18/9.5/8
20/11/8
20/11/9
20/11/10
My mods and setup are below in my signature. Any other setup tips for ice racing would be greatly appreciated! Thanks again
_________________
02 RAPTOR - FULL SPARKS X6, LONESTAR +3+0 A ARMS, PRO FLOW w K&N, TCS 3 RATE FRONT SHOCKS W ADJ. REZZIES AND ZPS, GYTR JET KIT, REAR SHOCK REBUILD (ELKA ZPS), SS BRAKE LINES, KENDA KLAW TIRES, AC PRO PEGS, RENTHAL BARS, RPM +5 AXLE, PRM REAR SKID, IMS DIRECT LINK SHIFTER
Old Oct 11, 2004 | 01:30 PM
maddog56's Avatar
It depends on what kind of track you are going to be racing on. If its a short track you will want the 18's. If its a 1/2 mile or bigger you will want the top end of the 20's.
Check your pm's.
Old Oct 14, 2004 | 07:28 PM
jerstilly's Avatar
BUMP!
Old Oct 14, 2004 | 08:01 PM
Hozed's Avatar
the lower to the ground the better... even if the straits are long id run the 18's... unless they are really long... like 250ft plus...
1 stud per lug is all you need... its about 650 studs for 1 rear 18 inch tire... trust me... i studded 3 sets over the winter... that sucked...
the .125's are fine... but we bumped alot and those rims just crumbled...
as for fronts... the holeshots or razrs are excelent... u can just stud the middle row of tread and they work mint.
Old Oct 14, 2004 | 09:46 PM
maddog56's Avatar
That might be ok for playing around on a pred, but if you are going to be seriously racing a raptor you need a lot more grip than one stud per **** on a set of 18's.
Old Oct 14, 2004 | 10:59 PM
Raptorboy4life's Avatar
LOL HOZED.. you need more studs in your fronts man or a lot of PSIIIIII lol
Old Oct 14, 2004 | 11:49 PM
Hozed's Avatar
i ran high psi in them... the side screws never touched.
those cheng shings were on a yfz, 450r and a shee.... 1 stud per **** is all that will fit... they are a tiny tread... smaller than a turf tamer.
Old Oct 15, 2004 | 02:35 AM
maddog56's Avatar
Thanks, I know about cheng shins. I've been running them since the late 80's. And they will fit much more than one per lug...
yfz, 450r and a shee live on wheel spin. the yfz and shee are high rev engines that like tire spin. the r needs less traction to cope with its low end gearing issues.
Old Oct 15, 2004 | 07:05 AM
Hozed's Avatar
much more than 1 per lug??? right... how many do you fit? the lug is like 1/2x3/8 if that. 1 screw in the middle in sufficent. more than 1 per lug gets very exspensive... its 650 per 18' tire with 1 in each.... 2 would be 1300... and you fit "many more" so your looking at what 2400 per tire? not everyone has that much money to blow on studs... its about 50$ per 1000 for the kind we get... so thats 250$ just for the rears they way you say u do it... then another 50 for the fronts...
Old Oct 15, 2004 | 12:11 PM
maddog56's Avatar
Thats the difference between racing with the big boys and playing with your buddies hozed.
