raptor problem
Old Oct 11, 2004 | 12:54 PM
Ace17's Avatar
Default raptor problem
i was at a local track on saturday, and at the start my bike was workin fine, but as the day went on my first gear started boggin(sp?) really bad, so bad that when i was lettin out the clutch had to rev it pretty high to even get it goin, but every other gear was workin fine, and every once in a while, the bike would nogg rite out and stall, does anybody know wat this is? is it my carbs or wat? or is it my gearing goin?
thanx for the help
Old Oct 11, 2004 | 02:37 PM
HughJazz's Avatar
Check you axle bearings
Old Oct 11, 2004 | 04:04 PM
Raptor149's Avatar
You've got an '01 Raptor with tranny problems, it sounds like. Check all the stupid stuff, oil, clutch cable, anything that would create a drag. It's not your carbs if all the other gears are working fine. Maybe check the reverse cable/lever/switch, make sure everything's okay there.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
