for those who own a raptor 350
Old 10-11-2004, 08:59 PM
2FAST4URASS's Avatar
Default for those who own a raptor 350
if you want a wider front take off ur factory tires get urself 2 new 4 new valve stems turn the old one inside out make it so it faces in to the tire cause if you dont the arm will knock it off and thenget a drill bit of the rite size and drill a new hole on the new side slide you in a new stem an pop the tire back on and bam you get about 3 inches on each side for about 4 dollars and if you have fatory exaust pull the baffle out sounds so much better not too loud just nice and deep and if you want to keep it quiet take the baffle out and get a grinder sawzaw etc; cut the screen off and put ur cap back in no louder but less restrict'ing [img]i/expressions/face-icon-small-happy.gif[/img] i hope this will help someone
p.s removeing the baffle you can feel
a little power gain off bottom end but dont
expect not radical gain
Old 10-11-2004, 09:03 PM
recon99's Avatar
turning the wheels that way can cause the front wheel bearings to wear out much faster than with the wheels the way they are designed to be mounted, especially if you use your quad for jumping
Old 10-11-2004, 09:06 PM
2phast4u2catch's Avatar
it will also cause a bump steer
Old 10-11-2004, 09:07 PM
what is bump steer
Old 10-11-2004, 10:06 PM
idk how to describe it lik the front tires will jump as u tirn lik it was going ova jumps i guess idk sum1 help me
Old 10-11-2004, 10:14 PM
RaptorRida419's Avatar
how do u get the baffle out i want to get it out but i dont wanna mess anything up or break anything so can u tell me how to get it out and if i do take it out can i put it back in?
will taking the baffle out hurt anything on the fourwheeler? and if it get mud or water or something in it will this hurt it?
Old 10-11-2004, 10:17 PM
FoxSpirits's Avatar
that is the most retarded redneck mod ive seen today...[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old 10-11-2004, 11:47 PM
but it works [img]i/expressions/face-icon-small-happy.gif[/img]
Old 10-12-2004, 12:13 AM
maddog56's Avatar
Flipping the rims certainly isnt a new idea. Nor is buying rims with a wider offset. Or you could buy some wheel spacers.
To be honest, not everyone has the money for a set of a arms, or doesnt want to spend that much. These are just some of the ways to cheaply widen your machine. You will sacrafice some handling and reliability aspects in exchange for the width, but thats how modifications go.
Old 10-12-2004, 12:19 AM
maddog you are the man no one could have said it better.... people and there smart azz comments umm humm clears throat ((fox))
Quick Reply: for those who own a raptor 350
