Solution needed to keep the Raptor front end down
Old Oct 12, 2004 | 12:52 PM
Sixgun's Avatar
Default Solution needed to keep the Raptor front end down
I need some advice on how to keep the front end of a raptor down when hill climbing. I have heard that aftermarket tires would help, but I think that would cause the quad to get more traction and make the front end lift even more while accelerating. Any comments or suggestions would help. Thanks
Old Oct 12, 2004 | 12:58 PM
Ernie660R's Avatar
JTM extension on the stock swing arm.
Old Oct 12, 2004 | 02:28 PM
warwgn's Avatar
lean forward!!!! feather the throttle, or swing arm extension!!
Old Oct 12, 2004 | 02:36 PM
YoungDawg's Avatar
If you are not hitting big jumps soften up your front suspension and stiffen the rear.
the weight transfer will change so it won't let it lift as easy. But you still need to lean forward.
We've done this on a few 690 raptors with a 14 front sprocket and it helps...
Old Oct 12, 2004 | 03:11 PM
garyc660R's Avatar
Longer swingarm or swingarm extension should fix the problem.
Old Oct 12, 2004 | 03:21 PM
1BADRAPTOR's Avatar
+6[img]i/expressions/face-icon-small-happy.gif[/img]
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
bucklove007
Jun 8, 2015 07:28 PM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
