What do I need??????????
Old 10-15-2004, 01:39 AM
1LeSSRaptor's Avatar
Default What do I need??????????
What's up everyone? Please help!!!!
I've been wanting to do away with the parking brake that I never use and never worked. Now I have a reason to. I let my little brother borrow the raptor and he called me up and said the rev limiter was stuck on. Found out that the spring on the brake attached to the swingarm is gone. I know I need a blockoff plate. What else do I need to get rid of the junk????
Thanks
Old 10-15-2004, 02:27 AM
maddog56's Avatar
Just a block off plate and you have to plug the parking brake wire into itself.
block off plates are about 10 bucks.
Old 10-15-2004, 02:15 PM
Hey maddog56,
What about to remove the brake assembly on the cluth lever? Do I need another lever, or does it just unbolt from the stocker?
Thanks
Old 10-15-2004, 05:02 PM
Jibrille's Avatar
All I used was a Black off plate, removed the wire, bought a YZ clutch perch and lever, and just swapped it around. Though you can just unbolt most of it off the stock clutch perch, I just bought new for looks basically.
Old 10-15-2004, 07:03 PM
maddog56's Avatar
Jibrille got it,
Your choice really. You can remove a lot of the clutter on the stock perch or you can buy a new one.
I will warn you that if you buy aftermarket dont go cheap. Those cheap ones will break in a heartbeat.
