Raptor owners, got huge problem
Old Oct 17, 2004 | 05:03 PM
King660r's Avatar
Default Smoke coming from the breather hose from the carbs
My build may start sooner than expected. I was out riding today and my raptor started cutting out and died. I looked down and smoke was coming from underneath the seat. I took the seat off and cranked the motor. White smoke is coming from the breather hose that was originally connected to the airbox lid before i took it off. What do you think? It only blows smoke while cranking the engine.
Old Oct 17, 2004 | 08:17 PM
King660r's Avatar
Default Raptor owners, got huge problem
Come on people, need some info
Old Oct 17, 2004 | 09:24 PM
RaptorOwner's Avatar
Just your compression and Spark plug. Sounds like its rings or the Piston........ Let us know what you find out.
Old Oct 17, 2004 | 09:50 PM
King660r's Avatar
oh and another thing, my coolant level is way over full, almost to the lid, dont know if that would indicate anything. I just dont really want to tear it down if its relatively something simple.
Old Oct 17, 2004 | 09:56 PM
Pull the plug and see if you smell any antifreeze on it.... Also the white smoke maybe burnt antifreeze. Check your oil level and color also.
Old Oct 17, 2004 | 09:59 PM
PolishCowboyPL's Avatar
I'm guessing that ATV engines aren't far from car engines so I'll put this in. On a car when you get white smoke it usually means you are burning antifreeze. Check the oil and the plugs to see if it smells or looks not right. You probably didn't run it long at all so you didn't burn any antifreeze hense the reason why your coolant tank is about full.
MIke.
Old Oct 17, 2004 | 10:06 PM
King660r's Avatar
First thing i did was check the oil level, the oil on the dipstick looked normal but wasnt a real good indication, any more possibilities?
Thanks a lot for the info!!!!
Old Oct 17, 2004 | 10:19 PM
Did you pull the plug?
Old Oct 17, 2004 | 11:01 PM
King660r's Avatar
Not yet raptorowner, Im in graduate school through the week, it will be this weekend before ill be able to look at it. THanks a lot!
Old Oct 18, 2004 | 12:02 AM
Turtler's Avatar
Bad head gasket is a possibility.
