not good
Old Oct 17, 2004 | 08:53 PM
03660's Avatar
Default not good
so i went to start my raptor ths morrning and smoke started to come out the exhaust, so i looked closer and there was oil dripping outof the end of the pipe and at the conector pipe. it is an 03 with a CT racing kit in it. any info would be great thanx mike
Old Oct 17, 2004 | 08:58 PM
7QuadSport7's Avatar
Default not good
yur piston rings are worn so your engine is burning gas and oil get it fixed from your dealer common problem
Old Oct 17, 2004 | 09:11 PM
86LT250RFatty's Avatar
Default not good
or you might of blown an oil seal or a gasket inside your motor and oil is leaking into the combustion or being sucked up into it.
Old Oct 17, 2004 | 09:13 PM
todster's Avatar
Default not good
sounds like rings,but i did have the same problem once and it turned out to be the carb leaking gas into the head while it was sitting. the gas mixed with the crankcase oil and made the oil burn and push out the exhaust.easy to ck just pull the dip stick cap
Old Oct 17, 2004 | 09:16 PM
Default not good
man did i say pistons crap im think about the ferrahi 360 spyder i meant the rings in the gaskets man its 10:15 already
Old Oct 17, 2004 | 09:25 PM
HughJazz's Avatar
Default not good
Check the oil level
Nondem
Feb 22, 2020 12:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
