WTF is going on with this YFZ?
Old Oct 18, 2004 | 01:02 AM
lilnotts's Avatar
Default WTF is going on with this YFZ?
my buddy has a yfz, and when he turns the key and holds the button to start it, it will roll over once, sometimes twice but never keeps going, just stops, what is going on with it? the battery seems to be fine, if you let go of the button and hit it again, it does the same thing, WTF?
Old Oct 18, 2004 | 01:03 AM
maddog56's Avatar
Have you checked the voltage on the battery? Or the wiring and connections?
Old Oct 18, 2004 | 02:12 AM
stevendsm95gst's Avatar
maybe a new starter?
Old Oct 18, 2004 | 04:13 AM
Hebs's Avatar
yep... sounds like the battery or a loose wire. I'd hook it up and verify that it has a good charge. Then get out the volt meter... check the fuses too!
good luck
Old Oct 18, 2004 | 01:01 PM
Blue450Rider's Avatar
OMG, the same thing is wrong with mine. I took my battery to a shop and it was low so I bought a new one. I installed it and there was still the same problem. [img]i/expressions/face-icon-small-frown.gif[/img] So I took my bike down to a local shop and there turned out to be some screw missing from my engine that was letting compression out so it wasn't able to start. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 18, 2004 | 02:06 PM
lilnotts's Avatar
the shop told him it was the battery too, so where is this bolt located on the motor?
Old Oct 18, 2004 | 08:42 PM
It's above the header pipe. When your sitting on it it shold be about level with your knee. The hole is pretty small like the diameter of a pencil, maybe a little smaller. I never even noticed it there before the hole showed up so if he doesn't see the hole it's probably alright. I don't know if a screw went in there or what, I don't have a lot of information on it, like I said, I never even noticed it before the problem.
