just got 12:1 piston
Old Oct 22, 2004 | 12:42 AM
hoop52's Avatar
Default just got 12:1 piston
Just got my 04waroir back. Had a 12:1 piston installed. Took it up the street, it backfired and popped. the guy that did the work said he change the jet to a 155. I think maybe i should change it to a 160. haven't checked the air screw yet. I'll bottom it out then turn it 2-2 1/2 turns out. any suggestions?
k&n filter
hmf slipon
Old Oct 22, 2004 | 12:46 AM
caliraptor's Avatar
I dont know your elevation but you might need a bigger jet...Im assuming your using a dyno jet...also, turn out the screw 3 turns....you might also need to go to a bigger pilot. Try to ride around and check your plug...that will lead you in the right direction.
Old Oct 22, 2004 | 12:57 AM
hoop52's Avatar
Thanks for info. i think i'll go up about 5 mm jet size each time and go from there.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
