I can't get the spark arrestor out of the pipe in my wolverine! i'l try most sugestions
make sure you have all the bolts off of the pipe and then work it out dont just pull u gotta worrrrk it!!!! and make sure ur not grabin the whole thing just the very tip part cuz that is wat comes out
hope that helps
hope that helps
Use a big pair of channel locks or vise grips and grab the end of the silencer. Take a hammer and hit the pliers as close to the jaws as possible on the shaft of the pliers. If your using channel locks, squeeze tight. It may take a few tries, but this method works well. Good luck.
