Raptor with a problem
Old Nov 6, 2004 | 09:15 PM
400ex5500's Avatar
Default Raptor with a problem
I have a 2003 Raptor that has developed a terrible squeak in the rear when you sit on it or the rear shock compresses or moves. I cannot tell if it is coming from shock or shock mount. Has anyone experienced this and if you have, What caused it or a fix.
Thanks
Old Nov 6, 2004 | 11:08 PM
caliraptor's Avatar
That happened to me too, it was the zerk fitting under the swingarm skid plate. I had to stand the quad on its rear and take off the skidplate to be able to get to the fitting.
Old Nov 7, 2004 | 02:28 AM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
It happend to me too, but mine when away all the suden.
Old Nov 7, 2004 | 09:00 AM
sixsixT's Avatar
There like a hyme (sp) joint, a little ball in the center of each end of the shock. Remove the shock bolt and turned the ball sideways in the shock put grease on it while rotating it in the shock and put it back together with the bolt tight and no more squeek.
Old Nov 7, 2004 | 09:05 AM
maddog56's Avatar
Heim [img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 8, 2004 | 03:25 PM
codykjwalton's Avatar
I just fixed this problem on my quad yesterday. all i did was grease all of the zerk fittings having to do with the swing arm. no more squeak.
Old Nov 8, 2004 | 04:03 PM
Raptor149's Avatar
Do what sixsixt says. It also helps if after every wash, you grease every zirc and/or hit all your pivot points with WD40 and some lithium grease.
If you're riding your quad in extremely dusty conditions without having lubed the shocks and pivots, dust and heat build up will cause these spots to squeak.
Old Nov 8, 2004 | 10:39 PM
Humbert's Avatar
I HAD THE SAME PROBLEM. I JUST BUSTED SOME WD40 AND SPRAYED IT ON THEIR. JUMPED ON THE BIKE , AND KASSAM ALL GONE.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
