Bigbear POPS
Old Nov 8, 2004 | 08:53 PM
03250bayou's Avatar
Default Bigbear POPS
occasionally when im riding my bigbear will pop...sounds like a gunshot...is this a problem that needs to be fixed?...or is the jetting just a little off...it usually happens when im going down a hill in 5th gear without the gas...right when i get to the bottom...thanks for your help...
Old Nov 8, 2004 | 08:57 PM
RoscoePW's Avatar
my friends scrammy, when you give it gas, then let off completely does the exact same thing... BAM right, its loud as hell and cantbe good for the quad i suppose... good luck.
Old Nov 9, 2004 | 01:21 AM
hondabuster's Avatar
Jetting is off just a little, or the intake has a leak, or the exhaust has a leak.The popping is a symptom of a lean idle circuit.
If you dont have any leaks, turning the mixture screw out 1/4 turn, should stop the popping.
Old Nov 9, 2004 | 10:06 AM
03250bayou's Avatar
how should i check for leaks? and turning the screw out will richen the mixture right?...thanks...nothing is wrong besides that..its just really annoying
Old Nov 9, 2004 | 10:21 AM
An exhaust leak will make some noise, usually sounds like a valve clacking. Look for carbon around the joints, which shows exhaust has been leaking. Try snugging up the intake bolts, and the clamp on the carb. If those look ok, then id turn out the mixture screw 1/4 turn.
Old Nov 9, 2004 | 03:41 PM
RoscoePW's Avatar
do you know where the mixture screw is on a scrambler?
Old Nov 9, 2004 | 03:48 PM
partsland
Looking at this picture, its number 32 for a 500 scrambler. Its on the bottom of the carb, in the recess, just forward of the float bowl.
Old Nov 11, 2004 | 01:13 AM
IDLE's Avatar
It may be a bad cam, my friends big bear did the same thing and it kept getting worse till we replaced it and our sportsman did it to.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
Rooky
Sep 9, 2015 03:16 AM
