the warrior trail Quad?
Old Nov 15, 2004 | 10:23 PM
  #21
warriorbansheeboy's Avatar
Default the warrior trail Quad?
the wolverine is a great quad, good luck
it lacks speed though, its the same as the warrior only MUCH MUCH HEAVIER
Old Nov 15, 2004 | 10:57 PM
  #22
blindside350's Avatar
I believe warrior is a good trail quad, but not the best. I think the 05 400ex is better since it has reverse now...but its better than some
Old Nov 16, 2004 | 02:44 AM
  #23
MNWolverine01's Avatar
The warrior is 405lbs dry weight and and the wolverine is 477 lbs. That isn't MUCH MUCH HEAVIER, besides for 4x4, bigger tires, a back rack, and a extra gallon of gas in the tank, it is well worth 72 lbs. For you to say the wolverine lacks speed, I doubt you have ever driven one.
Old Nov 16, 2004 | 07:26 AM
  #24
heatseeker8's Avatar
Tue November 16, 2004 1:44 AM (NEW!)
Quote
Quote
Wrong..warrior is 375 DRY
Old Nov 16, 2004 | 12:01 PM
  #25
DuneRider650's Avatar
I ride a little here and there......
Warrior 375 DRY what???????? that would be the same as a 400ex and i no the warrior is heavier than the 400ex
Old Nov 16, 2004 | 12:08 PM
  #26
2FAST4URASS's Avatar
Thats what the new raptor/warrior weigh's
Old Nov 16, 2004 | 12:11 PM
  #27
because im pretty sure they made it lighter
Old Nov 16, 2004 | 12:28 PM
  #28
UltimateAussie's Avatar
yeah the new raptor 350 is surly lighter that was one of the reasons they made it, to improve on the warrior
Old Nov 16, 2004 | 12:56 PM
  #29
Quote
Quote
Heatseeker,
Please get your info straight before chiming in on the discussion. The new raptor 350 weighs 375 lbs dry, this discussion about a warrior which is 405 lbs Dry. They are similar, but they are NOT the same quad.
Old Nov 16, 2004 | 05:32 PM
  #30
Wolverine2003's Avatar
Well, I've got both the Wolverine & Warrior. The weight isn't very noticible unless you're in some really tight trails or jumping anything over 4' high, and that's more the 7" of travel than the weight difference of the Wolverine. If it's rained a lot and the trails are filled with water or we're doing some climbing over dirt piles, rocks, or ditches I take the Wolverine. If the trails are drier or I want to catch air over 4' I take the Warrior. They're both very good all around machines.
