JETTING
Old Nov 11, 2004 | 08:58 PM
codykjwalton's Avatar
Default JETTING
I dont know if my 02 raptor is jetted or not. It has a pipe on it and a proflow K and N filter. I keep the lid on and a snorkel. i dont know how to tell if i should rejett or not.
what i did was changed the sparkplug and ran the quad for about 5 min, then i took the plug out and checked the color. It was a very dark brown. I know that the optimum color is a tan. but with this coloring on the plug do i need to rejett and is there any other way to tell if i need to rejett?
By the way . the quad runs really well. no backfiring or chugging. seems strong so far.
Old Nov 11, 2004 | 09:19 PM
JTHREE's Avatar
Default JETTING
Tan to chocolate brown is correct. If the plug is dark brown then you're on the rich side of having it jetted correctly. That is good in my book cause the motor runs a little cooler. As long as the quad doesn't sputter when the throttle is held wide open for a couple of seconds your not too rich. Don't get the sputtering be confused with the rev limiter kicking in though. Hope this helps.
Old Nov 11, 2004 | 09:23 PM
maddog56's Avatar
Default JETTING
Plug could be dark for many reasons. Unless you installed a new or clean plug, did a top end run and shutoff, and then looked at the plug you cant go off the reading.
If it backfires, its lean. If it bogs anywhere in the rev range, its rich. You need to open the carb up and see what you have in it for jets and tune it accordingly.
Old Nov 12, 2004 | 12:40 AM
Default JETTING
for a top end run and then shuttoff. do i let the throttle wide open in 2nd gear and then kill it while still having the throttle wide open at the tope end of 2nd gear?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
