My wifes 04 660Raptor wont start, HELP!
Old Nov 12, 2004 | 01:28 PM
caliraptor's Avatar
Default My wifes 04 660Raptor wont start, HELP!
Maybe since you moved to 7K above sea level your jetting is off? Maybe going down 1-2 jet sizes will help [img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 12, 2004 | 06:10 PM
Markitfunded's Avatar
OK, it looks like I may need to pull the float bowl's....but that dont look nearly as easy as on my Baja X.
Could use some advise from those of you in the know, Do I need to pull the whole carb out to get them off ? And if so, how much other stuff needs to come off to get to it, plastics, gas tank , etc ???????
Thanks
Old Nov 12, 2004 | 06:17 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Ohh good times... neccesary = Front fenders, seat, tank... to make it all easier = rear fenders and airbox. Git r naked. [img]i/expressions/face-icon-small-wink.gif[/img] Raptors suck for carb access its the most retarded design anyone could have ever concieved. WTF did the designers not think people would change anything or the bikes would require carb maintanance?
Old Nov 13, 2004 | 12:48 AM
Thats what i was afraid of. So what your saying is the carb's gotta come out to access the float bowl?
Totally lame!!!!! Very unhappy I am. Oh well, would rather go through the pain than take it to a shop and have to admit i could'nt fix it myself.
Old Nov 13, 2004 | 01:13 AM
  #15
wshrdskin's Avatar
Just take the front plastic off, gas tank and carb cover (rubber). Pull the carbs out of the boots, flip them over and lay it on top of the motor (Rubber cover on top of the head). No need to disconnect the cables from the carb. No need to take the rear plastic off. Removing the air box will be helpful. A pain the first time but easier the next times if you cut the pointy part of the t!ts off that go into the holes, you'll understand when your taking the air box out. If your going to completely clean the carbs then you'll want to remove the cables and take the carbs all the way out. Otherwise its a 45 minute job taking your time. I know it's not the couple minute job like on the DS but it is what it is.
Old Nov 13, 2004 | 09:49 PM
  #16
YAHOOO!!!!
Got it running.....Pulled the carb cleaned the jets, fresh fuel and I'm back in biness.
I'll know better next time to leave it sit for so long with fuel in it. Should I run her dry the next time?
Old Nov 13, 2004 | 09:58 PM
  #17
wshrdskin's Avatar
Good deal.
If your going to leave it sit for an extended period of time, It might be a good idea to drain the carbs before you store it away.
neilbedwell
Nov 10, 2018 11:02 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
CanadianViking
Feb 16, 2001 11:56 AM
2punksdad
May 23, 2000 01:46 AM
