Banshee problems
Old Nov 11, 2004 | 11:40 PM
GeorgiaBanshee313's Avatar
Default Banshee problems
Just put a knew top end on my 01 Banshee. I went 60 over has pipes and is jetted. I have a hard time getting it to cold crank, after i get it running it runs great and if i shut it off and go to start it back up it will fire right up can't figure out the problem
Old Nov 12, 2004 | 09:49 AM
Hiram's Avatar
Clean out your carbs out real good, your pilot jet may be cloged, also check the choke plunger to make sure it's sealing, and last make sure the reeds are not cracked or chiped and that they are closing enough to seal.
Old Nov 12, 2004 | 02:57 PM
enFORCER's Avatar
And after you do that, put an hour or so on the engine to seat the rings and then do a compression check..
Old Nov 12, 2004 | 06:18 PM
Bubba297's Avatar
If you didnt replace the pilot jets I would go to a 35 and that will greatly help your cold start and bottom end response in the cooler weather. You might have to play with the needles and/or air screws.
Old Dec 13, 2004 | 09:36 PM
I figured the problem out. Whoever had the SHEE before me switched the carb bowls when they were cleaning them. One of the carb bowls has a jet in the bottom of it, and that bowl has to be on the carb with the choke lever. So if anyone ever cleans there carbs and switches out the bowls it will be damn near impossible to crank the SHEE! thanks for all yalls info
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
