what tooth sprocket to use on banshee
Old Nov 14, 2004 | 03:05 PM
whseddon1's Avatar
Default what tooth sprocket to use on banshee
i need a new front sprocket on my banshee what does the different number of teeth do for performance
Old Nov 14, 2004 | 03:11 PM
2004LEBANSHEE's Avatar
I run a 15/41. Stock is a 14/41. I have some mods and the 15 pulls more and makes less shifting in the trails due to the taller gears. For me. Some people have other opinions. I personally dont like a smaller one because it wheelies more and I have to shift to much.
One tooth up front is 3 in the back I believe.
Old Nov 14, 2004 | 03:23 PM
treylaxbanshee's Avatar
hey Lebanshee
have you ever tried Vito's Degree Keys, if so ever had any problems with them.
Old Nov 14, 2004 | 05:15 PM
No I have not tried them. I have herd they are prone to shearing off. I just modded my stock timing plate to 4 degrees. A little safer.
Old Nov 14, 2004 | 10:12 PM
whseddon1's Avatar
so the less teeth the quicker the acceleration more teeth longer shifting stages
Old Nov 15, 2004 | 10:23 AM
kinda.
Front
More teeth- Higher top speed, longer gear
Less teeth- shorter gear, lower top speed
Rear
More teeth-shorter gear, lower top speed
Less teeth-Higher top speed, longer gear
Front gears are about $8 and rears are a bit more $30
Oh 1 in front is 3 teeth in the rear.
buddieboy
Dec 9, 2016 05:50 PM
Kaleb_00
Jun 1, 2016 09:15 AM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Jul 7, 2015 11:00 PM
